Zyxel Multy M1 Sistema WiFi 6 AX1800
Specifiche sistema
Speed Rating (per unit)
  • WiFi 6 AX1800 (574 + 1201 Mbps)
Wireless Standard
  • IEEE 802.11 b/g/n/ax 2.4 GHz
  • IEEE 802.11 ax/ac/n/a 5 GHz
  • 2.4GHz AX: 2x2 (Tx/Rx) 1024 QAM 20/40MHz, up to 574 Mbps
  • 5GHz AX: 2x2 (Tx/Rx) 1024 QAM 20/40/80MHz, up to 1201 Mbps
  • Compatible with 802.11a/b/g/n/ac WiFi standards
Transmission Speed
  • Transmit & Receive:
    • 574Mbps* for 2.4 GHz
    • 1201Mbps* for 5 GHz
  • MU-MIMO capable for simultaneous data streaming
  • Beamforming for 2.4GHz & 5GHz bandsCellular and Ethernet WAN failover and failback
App e gestione
Multy app
  • Easy to setup
    • Support myZyxelCloud SSO (Single-Sign-On) system
    • Support location check to suggest Multy node placement for better signal strength and coverage
  • Support Internet access control
    • Block or allow specific group based on time schedule
  • Support guest network setting
    • Share network name and password via QR code for guests
    • Monitor of active concurrent guest devices connected
  • Diagnose network via speed test
  • Push notification
    • New device connected
    • New firmware available
    • Speed test result
  • Remote management
  • Automatic updates for new features
  • Support language: EN/ZH/DE/ES/FR/IT/PT
Software
  • Security
    • IPSec Pass-Through
    • PPTP Pass-Through
    • L2TP Pass-Through
    • VPN Client/Server Support (OpenVPN)
    • WPA3-PSK
    • WPS Support
    • Guest Network
    • Automatic Firmware Update
  • Wireless Features
    • Guest WiFi
    • WiFi Protected Setup (WPS)
    • WiFi Multimedia (WMM)
    • Auto channel selection
    • Support 3 SSIDs for multiple purpose
    • Multicast-Unicast Conversion
    • Traffic separation from host network
    • Band Steering
    • AP Steering
  • Routing Protocols
    • WAN type: Static IP, DHCP, PPPoE
    • IGMP v1/v2/v3
    • Auto-IP change
    • IPv4/IPv6
    • Network Address Translation (NAT)
    • DHCP server/client
    • Dynamic DNS
  • Firewall
    • Stateful Packet Inspection (SPI)
    • Deny of Service (DoS) Prevention
    • MAC Filter
    • TCP/IP Filter
  • Operation Mode
    • Standard mode (Router mode)
    • Bridge mode (Access point mode)
  • Web Browser
    • Advanced wired & wireless setup and management
    • Diagnose & speed test
    • Parental Control
Hardware
  • CPU: 880 MHz Dual-Core
  • Memory: 256MB RAM
  • Flash: NAND Flash 128MB
  • Antenna: 2 Dual-Band Internal Antennas
  • Buttons:
    • LED On/Off
    • WPS
    • Reset
  • WAN: One 10/100/1000 Mbps Ethernet RJ-45 port with auto MDI/MDIX support
  • LAN : Three 10/100/1000 Mbps Ethernet RJ-45 ports with auto MDI/MDIX support
  • LED indicator: Status indication
  • Power: 12 V DC, 1.5 A
  • Power consumption: 15 watt
Informazioni e supporto Zyxel Multy M1
Sito Zyxel: Multy M1
Documentazione: Guida installazione rapida e manuale
Software e firmware: Download
Specifiche complete: Sito Zyxel
1 Mi Piace
Qualcuno l’ha provato?
99€ per il KIT da 3 mi sembra un affare.
