@luco ti ringrazio per le prove.
Una curiosità… se non ricordo male hai la prima versione del 7590 AX, quella “bassa” per capirci, come va con la temperatura?
La trovi nel menu Sistema → Monitor per l’energia → Statistica
Grazie a te per l’aiuto
Si ho la prima versione hardware che non ha le feritorie laterali.
L’ho messo appoggiato al muro in verticale
Se lo metto in orizzontale diventa bollente e la temperatura supera di molto la seconda linea partendo dal basso, in pratica arriva quasi alla linea rossa.
Quando è in verticale (installazione a muro) la temperatura va benissimo.
Sono quasi 25° di differenza!
Lascialo sempre verticale e non spostarlo
Disponibile nuova versione beta FRITZ!OS 7.39-96976, di seguito le modifiche dalla versione 07.39-96555
System:
Improved Email address saved in user account can be deleted
Improved Wizard for first configuration with option for fax sending or for fax sending and reception
Improvements of FRITZ!OS within FRITZ!Labor
DSL:
Improved Display of sync data rate instead of available data rate on the “Overview” and “Online Monitor” pages
Internet:
Fixed “Internet address of this FRITZ!Box” was not always shown for WireGuard connections
Fixed Failed internet access logins were not listed in the event log
Fixed Filtering of websites deemed harmful to young people (German BPjM filter) could not be refreshed under some circumstances
Fixed In rare cases, the e-mail notification about a successful update was not sent via the MyFRITZ! platform
Fixed In very rare cases the request for an update was no longer performed and the information about the mesh master was not transferred to MyFRITZ!Net
Fixed No NTP time determination was possible without a DNS server provisioned by the internet provider
Fixed WireGuard VPN connection between dual-stack and DS-Lite tunnels was constantly disrupted under certain conditions
Improved For VPN connections, internet access was sometimes prevented by parental controls
Wi-Fi:
Fixed “Start WPS” button on the “Wi-Fi / Security / WPS Quick Connect” page did not work
Fixed In certain scenarios Wi-Fi occasionally could not be enabled or disabled with the FRITZ!Fon
Fixed Throughput problems fixed for 160-MHz channel bandwidth (5-GHz band) with some Huawei devices (including Mate 20 Pro, P30) (6591, 7590)
Improved Improved automatic channel selection on the 5-GHz band in cases of Radar interference (7530)
System:
Improved Changed behavior of buttons at the lower end of the page
Improved Larger text in many tables
Repeater:
Fixed Multiple DFS wait times after first configuration
Si è aggiornato nel pomeriggio e finalmente i menu sono tutti in italiano
Secondo me manca poco al rilascio della 7.50
Disponibile nuovo aggiornamento 07.39-97059 Labor
# New functions and Improvements of FRITZ!OS 7.39-97058/97059/97060/97061/97062/97063/97064
## Internet:
- **Change** Updated provider list for internet access
# Improvements of FRITZ!OS within FRITZ!Labor
## Wi-Fi:
- **Fixed** Problems with selecting a manually chosen channel blocked by radar (7590, 6591)
- **Fixed** Problems with streaming applications (multicast) resolved (7590 AX)
## System:
- **Improved** Stability
Questa volta pochissime modifiche…
Stamattina ho trovato il router spento, non si accendendono i led se stacco e riattacco l’alimentatore, cosa mi consigliate di fare prima del reso amazon?
E’ appeso da mesi e il calore ha lasciato anche un alone nel muro bianco
Questa è la prova sul campo che la staffa per il fissaggio a muro in verticale non è idonea per la dissipazione perché la distanza dalla superficie evidentemente non è sufficiente a far fuoriuscire tutto il calore in eccesso: La prova è l’alone sul muro.
Si potrebbe verificare se è andato solo l’alimentatore o anche il dispositivo provando con un altro alimentatore con spinotto polarità e valori di alimentazione uguali (voltaggio, amperaggio e wattaggio).
Ma se hai le carte in regola per chiedere la sostituzione in garanzia fallo subito magari ti capita una unità V2.
Dici? Fissato a muro fuori era tiepido e anche la temperatura interna era molto piu bassa.
L’alone nero secondo me è stato fatto dal movimento dell’aria calda che saliva perchè è proprio dove c’è la feritoria più larga sotto i led, il muro non è sporco dietro il router ma sopra…
Ho provato un altro alimentatore leggermente piu piccolo ma non accende lo stesso.
Faccio il reso, grazie per i consigli.
Arrivata e installata la nuova versione v2 grazie amazon.
Effettivamente il router è molto più freddo di prima, lo lascio in verticale tanto ho già i tasselli nel muro.
Ottimo alla fine ti è andata bene
Hai notato differenze con la linea e il wireless?
Ciao, scusa per il ritardo… no è tutto uguale al vecchio.
Il nuovo ha una porta in meno, guardando le immagini credo sia la isdn.
Oggi il firmware sì è aggiornato a 07.39-98872 e finalmente i shelly non si disconnettono più
Si è la porta ISDN (FONS0), ti hanno mandato la versione 7590 AX v2
https://boxmatrix.info/wiki/FRITZ!Box_7590_AX_v2
